A/C does not blow thru panel vents
Yes the plug was on the back of the head unit. When I had my radio installed, they had to pull the head unit out and when they put it back in, they didn't plug everything back in properly.
joe
I have a 1997 F150 and I solved my problem.
There is a check valve between the battery and firewall. Mine was stuck under the battery cover and acid had eaten a hose and also corroded the valve. I went to Advance Auto Parts and bought a new check valve and it solved my problem. The check valve is what keeps the pressure constant when accelerating.
Steve
My 2003 Supercrew Lariat was alternating between dash vents and defroster vents.......then I had the battery replaced and now the air will only come out of the defrost vents. Do you have any pictures of where this "check valve" and "reservoir" are located?
