bypass pulley for a/c
I have a 98 f-150, with the 4.6 engine, I need a clutch, sounds like it going up, and I saw a part called bypass pulley, is that to replace the compressor? thanks, I posted on engines first didn't see this part.
Originally Posted by tbirdtommy
they do sell a AC bypass pulley. Its a pulley setup the goes in place of the ac compressor so you don't have to buy other belts n such
Its a different Tensioner arm for AC or Non-AC on the 4.6, 5.4, 5.8 etc motors.
I found the pulley that replaces the compressor. I have ordered it. How do you loosen the tension on the belt? the tensioner has three bolts, or is it some other way. thanks.
