Blend door replacement????????
Old Jan 14, 2008 | 10:32 AM
travr6's Avatar
I have been reading A LOT of threads about replacing this blend door.
I read some where that you can pull of the bottom part of the case it is in without taking the dash out.
Is this possible?
Can you replace the door/actuator without removing the dash?
I read one person saying it was 10 hour job and another saying it took him under 4 hours.
Is there a HOW-TO on this site for this fix?
I have a 98 F-150 with a 4.6
Old Jan 14, 2008 | 12:47 PM
Marinaro11's Avatar
I was able to replace the actuator in my 2000 Expedition 4.6 with out removing the dash. It was still a tough job becasue the acturator is really snug under the dash. It was a pain to get out but I got it done in about two hrs. However if you have to replace the blend door, then you are out of luck and will have to remove the dash.
Old Jan 21, 2008 | 06:00 PM
Colin Mason's Avatar
^ Agree with above just wanted to add that in a 98 truck if you are going to replace the blend door, you might as well spend the extra $150 and replace the heater core and blend door actuator while you're at it.
