Replacing A/C clutch please help
Old Oct 15, 2007 | 08:22 PM
davidshick2's Avatar
Replacing A/C clutch hub please help
I have my clutch plate scrathing the pully right now one of the 3 waights fell off. I want to replace the clutch hub, or at least I think thats what its clled I think thats all I need to replace.How exactly does this peice come off and can I do it when its on the truck. Please help its a 2000 F-150 lariat 5.4L 4X4 8 rib belt.
Old Oct 15, 2007 | 10:10 PM
jgonza5's Avatar
You need to borrow the ac clutch puller from autozone or somewhere like that.
http://www.autozone.com/in_our_store...ley_puller.htm
When using it, Don't pry against the compressor shaft (you can blow the seal). Put something across the casing to protect the shaft.
For my 98 Ranger it was about $100 at advance for the hub, pulley, bearings and coil setup, so I changed them all out. I was able to loosen the compressor and reset the pulley with a dead blow mallet without discharging the freon. The hub alone is $40 something.
http://www.partsamerica.com/ProductD...pe=385&PTSet=A
Old Oct 16, 2007 | 07:52 AM
projectSHO89's Avatar
You don't need that special tool. All you need is an 8mm wrench and a couple of screwdrivers.
1) Turn ignition to RUN without starting. Set A/C to any A/C position except OFF, FLOOR or VENT.
2) Locate the center bolt on the compressor clutch. Loosen it.
3) Turn ignition switch back OFF.
4) Remove bolt completely.
5) Gently pry the clutch hub disk off the shaft using the screwdriver(s) as needed.
6) When it comes off, watch out for small metal washers - those are your shim(s).
7) Install new hub with the shim(s)
8) Reassemble. Use procedure in step 1 to lock the system so you can tighten the bolt.
9) Test
Use a feeler gauge to measure the clutch gap. Desired gap is .014" to .033".
Do NOT purchase that aftermarket POS repacement hub from AutoZone, its dimensions are WRONG (found that out the hard way). Pick up the replacement Motorcraft part from a Ford dealer or from an online vendor.
Steve
Old Oct 16, 2007 | 02:58 PM
Steve83's Avatar
Old Oct 16, 2007 | 08:53 PM
Thanks for the step by step and for the diagram this makes everything so much easier to do I ordered the part today from the ford garage and am going to put it in on friday if its here. Will let you all know how it goes. Thanks again
Old Nov 6, 2007 | 08:51 PM
installed and everything running great thanks for the help everyone.
Old Dec 12, 2007 | 04:42 PM
jonezb's Avatar
How did you get the hub bolt off? I tried putting the key in the run position, but it never locked up.
Old Dec 13, 2007 | 12:02 AM
Did you also have the A/C control set properly?
Was it cold outside? If so, the pressure in the system can drop below the engagement point.
If all else fails, it's pretty simple to use a wrench to hold the hub. Just pick a size that your socket fits inside of, place it over the socket, then lever the arm of the wrench against one of the "nubs" on the clutch hub while turning the ratchet/socket.
Steve
Old Dec 13, 2007 | 11:44 AM
jonezb's Avatar
Steve
Thanks for all your help Steve! I got the bolt off, took the hub off, took the snap ring off, but now I can't get the pulley off, it's really loose, it seems like something is stoping it from coming off. It also looks like the bearings are not attached to the pulley, I don't know if there supposed to, but the new one looks like they are. Thanks again!
P.S. I live in Toronto, Ontario (Canada) so ya its pretty cold this time of year.
