2 BLowing levels will not work.
Old Oct 7, 2007 | 05:24 PM
ManDango's Avatar
I have a 1999 F-150 4.6L Supercab and my A/C and all the temp settings work great, but on the low and mid-low blowing setting nothing comes out of the vents.... Could it be the blower motor or the switch?!
Thanks,
Kevin
Old Oct 7, 2007 | 09:35 PM
Resistor pack.
Old Oct 7, 2007 | 11:16 PM
Steve83's Avatar
If anything OTHER than hi works, then it could be the switch, the wiring, or the resistors.
Old Oct 8, 2007 | 07:05 PM
Tschro's Avatar
blower problems
Hey mandango, I have the same problem. Someone mentioned the resistor pack. Where is that and how do you check it?
Old Oct 23, 2007 | 11:12 AM
97' Flareside's Avatar
Blower motor resistor replacement underdash
I had the same problem on my 97' Flareside!...Replace the blower motor resistor which is underneath the blower assembly on the pass side under the dash...It is held in by x2 5/16 head screws, with a wire harness/connector on it...It will take you 2 minutes!..The hardest thing is crawling under the dash!
It bought it through the "Team-Ford" folks that help sponsor this site...Received it in 1 day for $20.00 total....I recommend TEAM-FORD parts to all!
