Too much 134A??
Old Jul 9, 2007 | 12:45 PM
Truckfan2007's Avatar
Too much 134A??
I have a 1994 f150 and the compressor keeps kicking on and off, i bought a can of 134, the can came with a cheap gauge and it read that I had too much 134a. Could this cause the compressor to kick on and off???
Still not cooling down good!
Thanks in advance!
Truck
Old Jul 9, 2007 | 07:38 PM
Steve83's Avatar
That cheapo gauge is for checking WHILE the compressor is running, and it doesn't tell you how MUCH refrigerant you have - it only tells you how much PRESSURE the compressor is making. If it shows too high of pressure at the port in the R rear of the engine bay while the compressor is running, and then the compressor shuts off, you have big problems. Get a pro to check it out & fix it.
If the pressure comes down to normal, then goes below, and THEN the compressor stops, you can add a can of refrigerant yourself to see if it starts working right.
Old Jul 9, 2007 | 10:53 PM
projectSHO89's Avatar
Actually, those low-side-only gauges DONT tell you how much pressure the compressor is making, they read how much SUCTION the compressor can pull based on the existing charge.
Short-cycling compressors are almost always due to an undercharge which means a leak that must be repaired.
Steve
Old Jul 10, 2007 | 01:00 PM
zziggy's Avatar
walmart (chinese) parts won't make you an AC mechanic.
Take it to a Professional AC shop.
