Too much Freon?
Old Jun 7, 2007 | 12:52 PM
brownfordgt's Avatar
Too much Freon?
I think I have too much freon. Reason I added was that I had some blow out due to very high pressure becuase I had a failed e-fan. Wife's vehicle so when I got to it was already hot and the other efan was enough to cool it. After a couple weeks I find the failed fan, replaced it and went ahead and added a can of 134a to replace what I thought might have released out. Anyway my pressure are as follows:
At Idle
Outside Temp: 88F
Vent(max, recur) Temp: 50F
Low Side: 55-60psi
High side: 275pis
At 1300-1500rpm
Low side: 55-60psi
High side: 325psi
Both efans running.
Should normal pressures run about 30-35 on low side and about 225-250psi on the high side? If so, then I might have too much refrig?
?Rob
Old Jun 8, 2007 | 12:04 AM
projectSHO89's Avatar
Yes.
Steve
Old Jun 11, 2007 | 08:45 AM
Removed some from the system and not it cools down to 39F at the vent....
Thanks,
Rob
