06 - A/C not very cold
I'm in Phoenix as well. My 07 doesn't cool as well as I'm used to either. I've heard installing efans will help a lot but they seem to be very unreliable. I will probably jusy install a small - medium sized pusher fan to the condenser and see what happens then. I've also read in another thread on this board that Ford purposly went light on the freon form the factory as a cost saving measure. If you have it filled and checked at a dealership they will fill it to the proper amount....again just something I read on the forum.
I did some testing today. 06 F-150
108 Degrees outside.
The vent temp is about 50-52 degrees.
Cabin Temperature is 80-82 Degrees(This Sucks)
I took my 04 mustang out and did the same test.
Vent Temp was around 38-39.
Cabin Temp was 72(nice).
I am curious if I would be wasting my time taking this to the dealer.
Is a 50 degree output temp normal for these trucks?
I have had 2 scheduled services at the dealer in west Phoenix and both times have complained about the A/C, the first (5000 mile) the replaced some o-rings and recharged, the second they found nothing wrong and my air still sucks like most everyone's seems to. You might be wasting your time by asking them to check it, but it is under warranty and you've got nothing to lose. Strangely, a few weeks ago before it got blistering hot, I left my truck running with ac on while I was b.s.ing with guys after work, and I noticed my air is colder at an idle than while driving, anyone else ever notice that or am I out of my mind?
I gave up and went to Checkers and bought a recharge kit with a gauge on the bottle. Cost around 25 bucks. I brought the pressure right up TO the red line and it cools much better now. My time is worth more than the 25 bucks I spent then havin to make an appointment, drop it off, get a ride to work, go back etc etc.
Same Problem, Same Truck
Originally Posted by kwp06xlt
I recently (Feb. 07) purchased an 06 xlt that was used but only had 4k miles on it. The pickup now has about 7700 miles on it and the a/c does not seem to be as cold as it should be. It seems to take quite a while before it blows out even cool air and then it never gets as cold as I think it should.
My 2000 Ranger will put out ice cold air within minutes of starting it up. Hold your hand in front of the vents and it will cramp up from the cold!
Your a/c is operating just fine. It requires the flow of air to get it colder. I have had a temp gauge in mine from day one and on max a/c it reads 40. I guess Im lucky hearing some of you other guys say 50 is all you get. I still dont like it, but I have to live with it. I am coming from a vehicle that registerd 32* on its low setting.
This has got to be a normal thing.. Even my kids noticed the air in my '06 SCrew sux. Far worse than any other vehicle I have ever had.. I will have to take mine to the dealer this week to have an interior trim piece replaced.. I'll mention the air and see what kind of response I get.
Has anyone tried this Sub-Zero synthetic booster that is supposed to make it cooler and more efficient?
http://www.partsamerica.com/productd...goryCode=3571B
I want to recharge also!
Does anyone know an AC mechanic that can explain what makes on AC system colder than another?
Lets say you were to take 2 systems and fill them with exact same type and amount of R134a and made sure the system was tight and one was cooler by say 5 degrees. Is there a technical reason behind this?
