First Post - Please help
Old May 25, 2007 | 05:13 PM
ClemsonTiger150's Avatar
I have a 2000 F150 2wd with the base radio. Today I opened the dash just to see how hard it would be to add a satelite radio through the antenea etc.
I am not 100% sure these are related but now My A/C blower settings dont work. It is as if it is stuck on the lowest setting. Temp control works, selecting different areas (def) etc all work, but not the blower. It blows just very softly like on the lowest setting. Also changing to Max AC does not increase the blower speed as per normal.
I checked fuse 22 in the cab and 105 under the hood both seemed fine to me.
Any other ideas? Any help would be appreciated.
I did some searches which led me to check the 2 above but....?
Old May 28, 2007 | 10:06 AM
torkum's Avatar
The fan control **** has probably rounded off on the switch. Take the **** off and turn the switch to see if it speeds up the fan.
