Blend Door Actuator
Old Apr 17, 2007 | 08:24 PM
fabrication's Avatar
Blend Door Actuator
1998 F-150 5.4. Airconditioning is blowing Hot air. I think it is either the Blend door, or the actuator. I can hear the motor working when I switch it back and fourth Hot/Cold. So I am told it is possibly the actuator which I assume it is attached to the motor or the Blend door is cracked. I have been told that you do not have to pull the dash to change the actuator. How can I tell if it is the actuator or the door. If it is the actuator how much trouble is it to change. I hate to take it to the dealer. Thanks for any help
Old Apr 17, 2007 | 10:49 PM
torkum's Avatar
Pull the black plastic cover off that goes under the dash and over the tranny hump. You can watch the actuator work. I wouldn't recommend just changing the actuator without knowing the condition of the door.
Old May 6, 2007 | 05:34 PM
TurboDave's Avatar
Is there a way to have the system to default to cold instead of hot ?
Till a person has the time to pull the dash and do a proper job ?
