A/C lines warm/hot
Old Mar 16, 2007 | 10:19 PM
BlueOvalFitter's Avatar
Question A/C lines warm/hot
Temperature was up to 85 degrees today.My thermometer in my a/c vent has been reading 45 degrees.(usually reads 37-40 degrees)I've noticed the suction side line does not sweat like it use to.It feels kind of warm and the discharge side line feels kind of hot.Any ideas?
Old Mar 16, 2007 | 10:52 PM
torkum's Avatar
Check for system leaks. Use dye or a sniffer. Hope its not the evaporator core, watch the drain pipe if you use dye or put the sniffer at the outlet of the drain hose.
Old Mar 16, 2007 | 11:56 PM
Steve83's Avatar
The compressor outlet should be too hot to touch after it runs for a few seconds.
Old Mar 17, 2007 | 08:57 AM
projectSHO89's Avatar
Sweating of the lines is highly variable. Depends on your local humidity, the dew-point, and the temperature of the line.
FWIW, likely a low charge due to a system leak. Just hasn't gotten low enough yet to start short-cycling.
A set of manifold guages would be helpful for further detective work.
Steve
