Replaced Heater Core, cooling system pressure?
Old Feb 1, 2007 | 10:48 PM
mneal's Avatar
I replaced the heater core and blend door over the weekend and much thanks to those who posted tips here. The job was better then I thought it would be. I did have one brain fart putting the heater hoses back and actually put one together by installing the plastic clip, 2 o-rings and backing ring on the heater core and getting hose to clip it. Was a bear and I then realized I could "load" the hose and snap whole assembly to the heater core. Duh for me. My only question is now it seems like the cooling system never builds pressure , even when truck is hot. I am not totally sure how it behaved before though. The temperature runs normal , seems to be no leaks and heat seems fine but it worries me slightly the system never builds pressure . Is this normal/typical?
Old Feb 3, 2007 | 07:34 AM
mneal's Avatar
ttt...anyone?
Old Feb 3, 2007 | 07:45 AM
torkum's Avatar
Have you put a cooling system pressure gauge on it or are you judging by opening the cap?
Old Feb 3, 2007 | 08:04 AM
mneal's Avatar
Not sure how to put a gauge on it. I am judging totally by "feel" , that is collapsing upper rad hose. I expected it to behave like that for 1st temp cycles since the cap was off until thermostat opened, not I would expect some pressure to build.
Old Feb 3, 2007 | 12:13 PM
torkum's Avatar
First the pressure gauge goes on the radiator were the cap would go or for the F150 it goes on the reservoir tank. It is a cap with a pressure pump and gauge attached. You will not have any pressure until you put the cap on, without the cap you have a open system.
