Climate control Blower not working
Old Jan 15, 2007 | 04:59 PM
tgdavis's Avatar
I have a 2002 Supercrew with climate control and my blower stopped working last week (and its suppose to be in the teens this week). It's still making heat, just not blowing in any of the fan settings. The display indicated its changing from climate control to manual when you roll the switch all the way up,...but no blow!!! The fuse under the hood is ok. Any ideas would be appreciated.
Thanks Tom
P.S. I have 105K miles
Old Jan 22, 2007 | 01:22 PM
Bigghe's Avatar
I had the same thing happen on friday on my way to Chicago. I couldn't get any Service shop to look at it and I had to drive back to Iowa on Sunday. Took it to the local Service shop and they said the blower motor needed to be replaced. Hopefully, the part will be in this afternoon.
2007 Truck with ~1100 miles. It was a little chilly... the big issue was the windshield icing up yesterday and I had to use the washer fluid to di-ice every mile. Needed to pick up more fluid in the burbs on the way home.
Old Feb 13, 2007 | 08:41 PM
sauapower's Avatar
i had a similiar problem with my 94 sho. Turned out I needed to replace the blower control module. Since I'm assuming the design hasn't changed much since then. I would assume that could be part of your problem. The likely hood (imo) of the actual blower being dead is not likely.
Since its not that difficult of a location you probably could replace it yourself if you had the time and desire.
