heater prob...
Check for vacume leaks that will affect the vents movements. Poor vacume to the controls will cause vents to move to defrost or floor away from vent.
Just to be sure your not needing heat this time of year are you?
Temperature control is not vacuum controlled.
Check your temperature **** to see if it's stripped.
Check coolant level.
Verify BOTH heater hoses are hot after engine is warmed up.
Steve
Steve
