Heater broken - not a thermostat prob
Old Jan 22, 2005 | 05:12 PM
godetan101's Avatar
Arrow Heater broken - not a thermostat prob
My truck will not blow hot air. The air isn't cold (i.e., outside temp), and there's a new thermostat and coolant. Temperature guage is normal. I've read some things here about pulling off the **** to see if it's actually turning the control - can't get the **** off Any other ideas? My trusty mechaninc thinks it might be the "Heater control" device. He didn't want to take the time to look into it.
thanks!!
Old Jan 23, 2005 | 12:16 AM
97FordF150's Avatar
Couple ideas to check out,
1. Coolant level, Sure its full?
2. While running at normal temp, feel the heater hoses (carefully), they should both be at full temperature, HOT!! That will prove the flow in/out of the heater core is ok. If not - the water pump, thermostat, coolant level or plugged core could be a guess.
3. The dash Temperature ****?? get it off and check for the receiving hole to be cracked. That would prevent the **** from actually turning the control post.
Good Luck,
Don
Old Jan 23, 2005 | 05:01 PM
Yankee's Avatar
Just pull your **** off and get a new one. 99% of the time this is the prob because they crack just slightly and you really cann't see it. Donn't get fooled into a bigger problem.
Old Jan 23, 2005 | 06:09 PM
godetan101's Avatar
How do I get the **** off? Do I have to disassemble the dashboard around the radio/HVAC controls?
Thanks for your help
N
Old Jan 24, 2005 | 12:34 PM
Yankee7985's Avatar
Just pull on the **** to get it off. If you have to replace the actual rheostat, you have to remove the face plate for the heat control area. You may have to loosen the radio to get to the mounting screws for the control panel out. Once you have this done, just unplug the rheostat and remove it. Takes less than 10 minutes.
Old Jan 26, 2005 | 06:50 PM
godetan101's Avatar
Solved the problem - thanks!
Turns out it was a plugged heater core. $45.00 for a backflush (too cold to do it at home). Thanks for the help.
Nate
Old Jan 27, 2005 | 01:14 AM
Corpsie's Avatar
Re: Solved the problem - thanks!
FYI for future reference to all.
To Remove Temperature Selector ****: Orient it vertically (aka half way between full hot and full cold) and then pull it off.
