Two Questions
Old Oct 17, 2004 | 07:08 PM
intocable's Avatar
Two Questions
TWO QUESTIONS
1) Well I am a newbie around here and I own a 1998 Ford F-150 4.6 V8 4X4. When I was coming home from Texas to Nebraska, I had my air condition on and then I started seeing like this mist or fog coming out of my vents in the cab. The smell was fom antifreeze. Now I have added a 'stop leak' additive to the coolant and the smell comes back like in a week or so. It smells more if I turn on my heater. Can anyone help me on what is the cause of this? Thanks I will appreciate any response.
2) I recently changed my brake disks and brake pads. Now when I press on the brakes while driving, I get this squeaking sound. Anyway to get rid of it? Thanks again.
Old Oct 17, 2004 | 07:18 PM
Pestco1's Avatar
1) poss. heater core leak, hose connection tto the heater core. Most of the threads here in HVAC deal with this prob.
2) Did you use anti squeek compound on reassy. did you turn rotors or lust replace pads. Did you lube caliper slides. Might want to post this question in the brake forum to see if someone else has other suggestions
