continued troubleshooting a/c
Old Jul 5, 2004 | 05:03 PM
firedog's Avatar
Question continued troubleshooting a/c
thanks again to quintin for the reply, i disconnected the low pressure switch and jumped w/ wire to no avail, however i did also disconnect the high pressure switch (kind of sticks up on a funny angle in the other a/c line) put a little elect. grease on 'em plugged em back in and manually turned the clutch on the compressor ( w/ engine off) and voila it came on and was blowing cold!!! hmmm what do you figure??? it also sounded like a poss. leak somewhere near the condensor while it was running, and after turning off, does this make sense? or if it did have a leak would it be completely "dry"???
thanks again guys.
Old Jul 5, 2004 | 10:47 PM
Quintin's Avatar
If you're hearing hissing after shut down, that's just the system equalizing, if you don't see any oily residue or anything around the condenser or fittings, you're probably okay.
