2003 Supercrew Wet Carpet
Old Feb 7, 2004 | 10:42 PM
  #46
catch22's Avatar
I just noticed this problem today when I was vacuuming my truck. It was very wet under the passenger floormat, and I let it dry out while I finished cleaning the rest of the truck. Its been back up in the 80's the past few days so I've been using the a/c quite a bit. I'm going to see if this will happen again, and if it does I'll take it back to the dealer to look at. I need to get my oil changed and my roof repainted anyways.
TonyPTX, how long did it take the dealer to fix yours?
Old Feb 8, 2004 | 12:06 AM
  #47
TonyPTX's Avatar
catch22,
It took them one day. I dropped it off at 7AM before work and picked it up at 5PM after work on the same day. I ran the AC a few days ago and the water seems to be dripping outside now . The inside carpet is bone dry.
Hope this helps,
Tony
Old Mar 6, 2004 | 04:29 PM
  #48
FordMasterTech's Avatar
For all outta warranty situations
Jack up front end.
Go through wheel well to find the drain.
Install a rubber elbow (facing down) like is on some pcv valves.
BTW,,,, make sure engine is cool so you dont burn your hands/arms..
Have fixed ALOT of these!!
Just thought I'd share my trade secret with ya!!!!
FordMasterTech
Old Mar 6, 2004 | 06:26 PM
  #49
TonyPTX's Avatar
Re: For all outta warranty situations
Explains why I saw an itemized list of parts used that included a tube assembly from a crankcase vent (2L1Z 6758 CA) when I brought it in for warranty work. I was like, WTF....
To say the least, the leak no longer drips inside the vehicle, however I do see the water dripping all over the starter now. Should I be concerned about this?
TonyPTX
Old Mar 8, 2004 | 10:01 PM
  #50
No.
Would be no different than water splashing up from rain, etc.
I wouldn't worry about it
FordMasterTech
Old Aug 4, 2009 | 06:28 PM
  #51
vvfdfirefighter's Avatar
Condensation on passenger floor
I have an 05 SCREW and am having the same exact problem. IF you need assistance with this check out the TSB 07-13-5
Old Aug 5, 2009 | 07:27 AM
  #52
rp683's Avatar
Thank you sir!!! I appreciate your help!
