AC lek detection
Old May 29, 2003 | 11:16 AM
srfd44's Avatar
AC lek detection
Back in the day when R-12 ruled auto air conditioning, I bought an electronic leak detector (the kind that beeps rapidly when a leak was detected)
Will this unit work for the new R-134a gas?
Also can I use my old gauge set if i get the right adapters? I heard somewhere that the new gas may not be compatable with some of the rubber seals in the old gauge set. I don't want to contaminate my system by using my old gauge set if this is the case
Thanks for your replies
Old May 29, 2003 | 10:35 PM
Tailgator's Avatar
Yeah, it will still work with the 134a, but those detectors are not very accurate in finding the real small leaks. I prefer using the leak test dye & black light for leak detection. I suppose you could modify your old R12 gauges to work on the 134a system, but by the time you bought the adaptors & fittings you could probally buy a set of 134a gauges. IMO
