ac blows fuse
Old May 13, 2003 | 04:30 PM
rhk9x242's Avatar
Angry ac blows fuse
99 f150 6cyl blows fuse that controls ac clutch
Old May 15, 2003 | 11:32 PM
AzBeigeKRinAz's Avatar
Registered User
Like continuously blows fuses?
Old May 16, 2003 | 10:04 AM
rhk9x242's Avatar
Thumbs up
I PUT A NEW FUSE AND IT WORKS FOR ABOUT 20 OR 30 MINUTES
AND THEN BLOWS. continuously
THANKS FOR ANY INFO
Old May 16, 2003 | 10:28 PM
TexfordD's Avatar
check your relay..it may be going bad
Old May 23, 2003 | 04:27 PM
FordMasterTech's Avatar
Could also be the compressor clutch coil itself blowing fuses.
Just a thought
Good Luck
FordMasterTech
Old Aug 7, 2007 | 10:37 AM
tclybu's Avatar
More electrical questions
I am having a similar problem that suddenly my AC does not work. The fuse that blows is the #23 HEGO sensor fuse but my AC clutch stops also with that fuse. The strange thing is if I put a 30amp fuse in instead of the 15 amp one, it blows the #2 fuse which is the powertrain control module fuse and the truck will turn over but not start. It is a 2001 F150 with the 4.2L V6 motor. Hoping someone has an idea for me. I am way over my head on this.
Old Aug 8, 2007 | 08:22 AM
tmwilkin's Avatar
Any pointers on which relay ?
