Electronic Automatic Climate Control Replacement
Old Apr 29, 2003 | 09:11 PM
bgmjr's Avatar
Red face Electronic Automatic Climate Control Replacement
I am installing a new stereo in my 2002 F-150 King Ranch and I have scratched the Automatic Climate Control Module Under the stereo. I scratched the face of it pretty bad.
Does anyone know how much a new control module would cost? How hard is the procedure to replace the old one with a new one?
Any help would be greatly appreciated.
Old May 3, 2003 | 07:09 PM
FordMasterTech's Avatar
Changing it is just about as easy as replacing the radio itself..
just remove the bezel around the radio and take out the (4) 7mm or 9/32 screws. Disconnect wiring harness and vacuum harness..
Then of course reconnect everything.. & that's it!!
The cost is overwhelming.. about $400.00 last time I priced one.
Hope this helps.
FordMasterTech
Old Jun 16, 2007 | 01:09 AM
Texasaggie94's Avatar
I was wondering if it's possible to replace the manual climate control module in my 2001 F-150 Super Crew with a digital one from the same year group that was used in I think the Lariat or even the Expedition? I went to ford today and the said it's a lot more involved than just replacing the head unit? Any info is appreciated. Thank you.
Old Jun 16, 2007 | 10:53 AM
sysman_rick's Avatar
Post
To "clean up" the scratches,try rubbing compound(with a mild abrasive)in it.
