Compressor problem
Old Apr 28, 2003 | 01:56 PM
Ted'98's Avatar
Compressor problem
Over the weekend, my A/C stopped working. With the A/C on, the compressor clutch doesn't engage.
I have verified that the cycling switch isn't the problem (jumped the cycling switch connector and the clutch still doesn't engage). I measured 12+ volts on one of the wires going to the cycling switch.
I also unplugged the wiring harness from the compressor and found that one of the wires (can't remember the color) has about +7 volts going to it.
Is there only 7 volts at that wire due to the voltage drop of the diode? Or should there be a full 12+ volts going to the clutch?
Thanks for any help
Old Apr 29, 2003 | 06:48 PM
FordMasterTech's Avatar
What year model is it?? I can access my wiring diagrams for you..
Also, one thing to check is on the other wire at the cycle switch to make sure that you have a good ground..
FordMasterTech
Old Apr 29, 2003 | 08:56 PM
Ted'98's Avatar
FordMasterTech - thanks for the help. My truck is a '98 (I don't think it should matter, but it is a 4.6 auto).
I will check the ground tonight.
Thanks again.
Old Apr 30, 2003 | 09:37 PM
Ignore my previous comment... Checking for a ground there is incorrect.. Your resistance won't be accurate because it will be going through the compressor clutch before grounding..
I have sent you an email..
Follow directions inside for the help you need..
FordMasterTech
