2003 F150 Crewcab OEM Sat radio?
Did ford offer a Sat ready radio for the 2003 F150? Is there any way to add a newer OEM Sat radio in the old 2003? If I recall the 2004 interior changed so I don't think a newer OEM radio would fit without mods.
You will have a hard time finding a direct fit radio for the 03. The face looks like a larger more modern unit will fit, but once you get it open you'll see you need to trim the dash inside. If you go to the DIY section on this site, look for articles that mention double din or 2din units.
i have one....i'll get you model numbers as the "old" ones are offered across the entire ford line-up ...
depends on which kind of plug you have....this should be what you need
single CD, sat, aux
https://www.oemdirectradios.com/ford...o-6l8t18c869ac
depends on which kind of plug you have....this should be what you needsingle CD, sat, aux
