USB in the Rear
USB in the Rear
I have a 2005 FX4 with the audiophile stereo system and was looking to get the Pioneer AVH-P4400BH. I also have a droid incredible.
My questions are, the aux and USB are in the rear. How does this work for hooking it up to my phone to play music or putting a USB stick in? Do you run cables out of the back and put them in the glove box, ash tray, or center console?
I have seen the unit cheaper than Crutchfield but they seem to give you everything you need to install. Is there a cheaper option for this head unit but still have all the tech support and stuff to convert it to my truck.
dunno if you pulled the trigger already or not but...:
the aux and USB are in the rear. How does this work for hooking it up to my phone to play music or putting a USB stick in...unit comes with a 5ft or so usb cable to run with my pionr* i have my usb in the glove box for ipod or stick.
I have seen the unit cheaper than Crutchfield but they seem to give you everything you need to install. Is there a cheaper option for this head unit but still have all the tech support and stuff to convert it to my truck..... ucan look around for all the stuff but crutch gives u all teh harnesses and stuff u need to install really its a good deal
I am looking at the same unit they are 400.00 new on ebay .and the Matrix runs about 500.00 I keep reading about the screen freezing up .So have not pulled the trigger I mounted a usb cable where the coin slot was on my 07 looks factory had a extra 12volt accessory cover cap like whats on the right side. Oh This is where a 4x4 switch would go if it was a 4x4.
