Purchasing a double din
Old May 22, 2011 | 10:43 PM
migdaddy's Avatar
Whats needed to make a 7" double din fit in my 03 besides the metra kit 95-5818?
Old May 22, 2011 | 11:52 PM
sledman62's Avatar
Alot of patience....
You need a wiring harness adapter to hook to the factory harness. I used one from Best BHA1771, and it was easy to do. In my truck I had to cut out a chunk of plastic in the back of the dash, as well as the black plastic factory bracket. I don't have a Dremel, so I used the blade from my reciprocating saw, and did it by hand. It worked well, and was easier to control when trimming inside the dash. Mine turned out OK, but I still need to find some kind of trim for the sides. The one that came with the dash kit I bought from Best bfmk552, didn't seem to fit for me,and the one from the h/u was no help either.
If your going with a video unit, you'll want to use a bypass to allow you to watch video without the parking brake. On mine, it was a simple 12v 30a 5pin relay.
Old May 30, 2011 | 01:00 AM
BlownPony306's Avatar
Man I gotta try that. I already cut out the back side of mine to fit the 6 disc factory changer from a newer model. I'm diggin the double din though.
Old May 30, 2011 | 11:34 AM
DirtySCREW's Avatar
https://www.f150online.com/forums/he...2003-f150.html
---DirtySCREW
Old May 30, 2011 | 04:13 PM
Excellent write up! I know what my next project is now!
