Radio Help
Radio Help
I have a 2000 F150 and I cant get the radio out. I have the Ford tool to remove it but it wont come out I think I have 1 side loose but not the other. Want am I doing wrong?
Did you cuss at it while holding your tounge to the left? That usually works for me.
They can be a bit of a PITA at times. The tools need to go straight in, then push them slightly outward while pulling. You'll get it.
Andy
Andy
Push them into the holes until they click and that when you try and pull them out, they feel like they are stuck. Than bend the removal tools outward and try to pull straight out or wiggle the radio side to side while pulling out. Some radios are pains, some aren't. If you can only get one side out, try a butter knife and slide it on top or on the side and push the metal spring tab inward. Hope that helps
