06 Ipod hookup
06 Ipod hookup
Just trying to figure out which ipod hookup i need to connect with my 2006 f150 radio. I plan on keeping my stock HU, but really just need to find the right kit to hook up my ipod touch to the stereo.
What i really want is one that will let me use my ipod controls. Just because i can't imagine trying to scroll through 128 artists one line at a time.. Would get an aux input, but am wanting for it to charge it as well..
Was hoping to find one for around $150 or less.. at least that is what prices i have been seeing on them. So any recommendations??
http://www.bestbuy.com/site/iSimple+...ple&cp=1&lp=10
this will give you an aux input that you can control through the stereo...best sound quality.
http://www.bestbuy.com/site/iSimple+...mple&cp=1&lp=3
this is a FM Modulator that can be hooked up to charge...decent sound quality. just make sure you get a good ground or youll get bad interference.
Check out the Brandmotion adapter - I had one in my 06 Lariat hooked to my OEM HU. Changed when I moved to Kenwood HU, but the Brandmotion adapter worked well - easy to install and works with or without OEM Sat radio.
www.brandmotion.com
www.brandmotion.com
If anyone is interested, I found an ipod interface that works perfect. I bought it from here:
http://replacementradios.com/product...roducts_id=612
Sorry about last post
It looks like they only make adapters for 04, 05, 08. No 06. Thats what you have right? An 06?I did find this at crutchfield though. Go to crutchfield and look under car audio/Ipod & Auxillary adapters,, The one you might need for your truck is made by Percision interface eletronics. Here's the item number
Precision Interface Electronics FRD04-AUX Adapter
Add an auxiliary input to your 2004-up Ford factory stereo
Item #469FRD4AUX IN STOCK
Here's the description:
This adapter lets you listen to a portable MP3 player or just about any other external source through select Ford sound systems, by converting the CD changer input on the factory radio into an auxiliary input. The 14-1/2" cable has the factory-compatible 16- & 24-pin connectors at one end and female RCA plugs at the other. Warranty: 90 days.
Hope this helps man! Let me know.
Bryan
Bryan
another solution
Hey man, do you have a sattelite radio in your 2006? If not, this might be what you're looking for from crutchfield
BrandMotion Ford iPod® Adapter
For select 2005-up Ford-built vehicles without factory satellite radio
Item #212IFD004N IN STOCK
just bought one cause my panasonic touchscreen aftermarket was stolen. Went on ebay and looked around. Found one for 139.99. Works ok. Takes a little getting used to. I miss my aftermarket head unit.
you could have bought a new aftermarket HU for that price
http://www.bestbuy.com/site/Pioneer+...2100&cp=1&lp=1
Ipod control through the deck with the included cable.
