Removing factory HU....
Old May 8, 2009 | 10:57 AM
07F150OAKLEY's Avatar
Exclamation Removing factory HU....
I bought a new HU and I know theres a post on how to remove the factory HU somewheres but can't find one with pics....someone help me out!!!! Its a 07 xlt with the base(normal, no subs, no cd changer) system!!!!
Old May 8, 2009 | 12:51 PM
IDNC76's Avatar
do a search , its very easy
open the ash tray and pull the lower corners of the trim plate out, (they re just held in by clips, it may take a bit of force) once you get the bottom clips free , they re should be 2 more on each side and just work your way up.
once you get the trim plate off , you have to unhook hvac controls and the air bag light at the top og the trim plate.
and then the h/u is held into place by 4 bolts
Old May 8, 2009 | 12:58 PM
JJDH's Avatar
basically pull it of. get a pick with a hook, kind of like what the dentist uses on ur teeth. this way u dont mark up the surround of ur dash. once its a bit popped out u can pull on it using even pressure, slowly
Old May 8, 2009 | 04:12 PM
DJ2007's Avatar
This was very helpful to me. https://www.f150online.com/forums/20...tructions.html You don't need a pick, just your fingers.
Old May 8, 2009 | 05:40 PM
JJDH's Avatar
cool. tomato, tamatto
Old May 9, 2009 | 08:53 AM
thnx!!!!
