factory CD player help???
Old Jan 19, 2009 | 11:16 PM
f150fella08's Avatar
my dad has a 2003 f150 fx4 with about 90k miles on it and he said his cd player skips ONLY when hes driving but when he sits in the garage it plays fine
i have a 2002 f150 with the same cd player and i thought about swaping him since i have a aftermarket cd player...
anyone else had this problem or solved this problem
Old Jan 20, 2009 | 10:53 PM
nobody
Old Jan 21, 2009 | 07:25 PM
phattacorider's Avatar
Have you tried using a lens cleaner? I use one regularly with my DVD headunit. If it still skips after using one, then it might be a weak solenoid in the lens aperature (sp?) which would require replacement, those are a pain to try and get repaired. You shouldn't have a problem swapping since your trucks are the same generation.
Old Jan 21, 2009 | 11:10 PM
yea weve tried everything, except taking it apart lol guess ill just swap them out thanks for the help
Old Jan 30, 2009 | 07:02 AM
olds442111's Avatar
I actually had to take one apart and physically clean the lens with a q-tip and alcohol. Works perfectly now, but prior to the cleaning, wouldn't even take a disc laser lens cleaner. It was a last resort, and it worked out great.
