Sub in a factory Head Unit?????
Old Apr 21, 2008 | 02:05 PM
bigpapa's Avatar
I have a 06 super cab with the single disc CD player. I don't think its an audiophile because the truck doesn't have a factory sub. I was wondering if I could hook up a sub to my factory HU, and if so what all I need to do it. Im trying to build a system piece by piece, and I don't have enough money to buy the HU I want yet. Any help would be greatly appreciated.
Old Apr 21, 2008 | 03:22 PM
GJ Screw's Avatar
yes you can, use a LOC. Search for it..
Old Apr 21, 2008 | 04:21 PM
wakebrdr142's Avatar
LOC = Line out converter. This taps into your factory wires and you connect the rca cables from the amp to this.
Old Apr 22, 2008 | 08:05 AM
bigpapa's Avatar
thanks guys. I think someone had told me that before, but I wasn't really sure.
Old Apr 22, 2008 | 10:50 AM
worland's Avatar
Check my gallery. I've got a 6 channel 1200W amp and a couple of Infinity woofers hooked to my factory head unit. I went with an amp that offered speaker level and RCA inputs. No need for a LOC.
Instead of hacking into the factory stereo harness, I just make a patch cable from a Metra 70-5520 & 71-5520 harness. Using bullet or blade quick disconnects on the speaker input/output, 12 VDC switched and GND... you just connect your amp or other equipment into the patch cable. The patch cables makes it easy to add or remove components as finances allow.
Old Apr 22, 2008 | 12:26 PM
Low_e_Red's Avatar
Why not wire the LOC between the harnesses?!? Its much easier and will sound better that way...
Old Apr 22, 2008 | 03:48 PM
worland's Avatar
I prefer to have the converter built into the amp. The line converter in an amp is typically of much higher quality than those inexpensive $10-$20 LOC's everyone seems to like. I've been installing car stereo's for 22 years, and I lean towards the speaker level input amps as offering better sound quality than a $10 LOC.
Where do you typically place a LOC? Behind the dash trim, right? To adjust the gain, you have to pull off the dash trim and squeeze a tweeker in there. With my choice of amp, I just go to the control panel and all the gain, bypass and filter controls are easily accessable. I can fine tune the sound level and quality at any time. I am running 6 channels in my truck, so occasionally I like to bump up the gain on a channel, or tweek the bass boost on a channel for a particular CD.
Old Apr 23, 2008 | 02:36 AM
Low_e_Red's Avatar
Umm okay buddy.
Old Apr 24, 2008 | 02:31 AM
redragon's Avatar
hey Worland could you explain a little more on how you wired it to your harness im trying to do the same thing with my sub and amp maybe some pics?
that would be sweet thnx
Old Apr 24, 2008 | 11:39 AM
Low_e_Red's Avatar
The best way would be to go buy a LOC and wire it up from there.
