back up camera install Question
Old Apr 6, 2008 | 11:56 AM
shanecaseber's Avatar
I pick up a back up camera I take it that the power lead from the cam taps in to a reverse light power wire and just ground the black so it only comes on when in reverse am I right? What do I do with the wire coming of the HU marked reverse is this a sensing wire so it will go into that mode when in reverse do I tap this in the reverse power line as well the HU is a Jensen vm9022 thanks
Old Apr 6, 2008 | 12:10 PM
jrb03's Avatar
Take a breath!
The power and ground wire need to be tapped into an ignition switched power source. The wire from the HU marked reverse gets tapped into the reverse light wire, this lets the HU know your in reverse and it will automatically switch to the backup cam.
Old Apr 6, 2008 | 12:40 PM
Originally Posted by jrb03
Take a breath!
put wont that have the cam on all the time it has led lights on the side could i just pick up the taillight power lead so the cam only gets power when in reverse
Old Apr 6, 2008 | 12:52 PM
GoCats's Avatar
Where did you buy your camera?
Old Apr 6, 2008 | 01:52 PM
whitecrystal1's Avatar
Take a breath!
Old Apr 6, 2008 | 05:07 PM
jrb03's Avatar
Yes it will be on all the time, and what is wrong with that. If you power it to the reverse light you will only be able to use it while in reverse. If that is how you want it wired go for it.
Old Apr 6, 2008 | 06:13 PM
I think thats how I want it only in reverse do you know any place I can pick up a reverse line to tap for the head unit up front in the dash thanks
Old Apr 6, 2008 | 10:30 PM
jrb03's Avatar
No I dont. I always run the wire to the tail lights since you have to run wire back there anyways for the camera. I will tell you, there will be some times you wish you could turn your camera on without being in reverse.
