VSS in 2008 F-150
Old Nov 5, 2007 | 02:41 PM
JFisher08150's Avatar
VSS in 2008 F-150
I just purchased the pioneer AVIC-Z2, sirrius tuner, and reverse camera. I am getting ready to install it all in my brand new 2008 Supercrew, and was wondering if anyone knew what wire is the vehicle speed sensor that I tap into. Also any other tips would be appreciated.
Old Nov 6, 2007 | 11:24 AM
Low_e_Red's Avatar
God your smart!! Z2. Way to be. Anyways the VSS is gray/black pin 14 on main radio harness.
Reverse is green in DKP. (Double check this one cause its been a while.)
Old Nov 7, 2007 | 02:31 PM
Thanks, hopefully should be installing this weekend, any good places other that on the actual paint(I hate scratches especially on black) where I could place my antenna for my sirrius and the gps.
Old Nov 8, 2007 | 09:43 AM
edwards's Avatar
mine sits centered about a couple inches above the third brake light. all you have to do is take the third brake light off, pass your wire through(goes inside the cab) then across to where the seatbelt comes out(rear drivers side), behind there and down under the floor sill to the front of the cab then under the carpet and up into the dash. my truck is a super cab and the wire was just long enough with maybe a couple inches of slack.
anyways good purchase. i have the z2 and its awesome.
Old Nov 8, 2007 | 09:50 AM
edwards's Avatar
on mine it was a black wire with a pink stripe.
Old Nov 8, 2007 | 06:31 PM
Low_e_Red's Avatar
Ok. My mistake. Its been awhile.
Put the GPS in the dash behind the unit on the metal bar. Easy Install!!!
Old Nov 9, 2007 | 03:40 PM
Does it get good reception not having a clear view of the sky? Would the sirius antenna also work in this location?
