Head Unit - Brandmotion Ipod Direct
Got a quick question. I just bought the Brandmotion Ipod Direct Connect. I tried to put it in earlier but ran into a problem. On the back of the Head Unit there is the place for the 16 Pin Connector to hook up, but I can not find the wire that should hook up to it. Where would this be? I have a 2005 F150 XLT, without the satellite radio.
Originally Posted by sysman_rick
Is the HU a audiophile unit(MP3) ?
If I'm reading your quote correctly, then you have the socket for the 16 pin connector on the radio, but there isn't a connection from the vehicle to the radio. If that is true, then go ahead & plug both of the Brandmotion plugs into the radio & connect the 24 pin to the vehicle. You may need to have the iPod plugged in to the adapter before you turn on the radio. Having the iPod plugged in will make sure that the radio CAN bus is "activated" & then you should be able to push the AUX button & hear the music from the iPod.
I've not heard of the 16 pin connector going AWOL in the F-150, but the '07 Focus doesn't have a 16 pin connector & the Brandmotion adapter works with that vehicle (if the procedure described above is followed).
