Radio wont work!!
Old Oct 29, 2007 | 10:29 PM
circusmonkey's Avatar
Exclamation Radio wont work!!
Just bought a used 2005 supercrew and the factory 6disc radio works great during the daytime but at night when i turn the headlights on it wont make a sound but all the controls and everything else continues to work like normal. If i park it and turn the engine off the radio will start working again even with the headlights on. I have checked every fuse already and still nothing
Any ideas??
Old Oct 30, 2007 | 12:19 AM
Low_e_Red's Avatar
Hmm... sounds like some issue with the illum circuit but idk. Does it change at all with the dimmer in different positions?
Old Oct 30, 2007 | 09:48 AM
Unhappy
yeah the display changes brightness like it should when i turn the headlights on but the sound goes away unless the engine is turned off with the key still on
Old Oct 31, 2007 | 03:58 AM
DRJ's Avatar
DRJ
My stab would be something internal..like when you turn on your lights, it is possible the dimmer grounds out a speaker wire and causes your sound to turn off...a quick fix...cut the dimmer off.. recommended.. no.. recommendation..try a new radio...just my stab
Old Nov 3, 2007 | 02:41 PM
Talking
Turns out there was a remote start in the vehicle when i bought it. It looked like it was already half disconnected so i cut it all the way out and now it works great.
Anyone wanna buy a used remote start??? Cheap!!!!!!!!
Old Nov 4, 2007 | 03:25 AM
DRJ's Avatar
DRJ
Wow must've been a hack job! I'm happy for your truck!
