Radio Trim Panel Install
Old May 25, 2007 | 01:43 AM
Harley Boy's Avatar
Question Radio Trim Panel Install
Hey gang. I just installed a factory nav unit in a 06 F 150. It work great.
However, The radio sticks out and the trim panel won't snap fully inplace.
What can I do?
Old May 25, 2007 | 10:16 AM
kuruption's Avatar
What can I do?
Did you screw in the radio all the way?
The trim panel will stick out from the dash about 1/8" all around, too, which is normal.
Old May 25, 2007 | 12:05 PM
Harley Boy's Avatar
Head unit
Yep it's in there tight. The brackets are about a 1/4 back that the original radio. Do you know if I need to change the trim panel?
Old May 25, 2007 | 01:55 PM
luke280's Avatar
How bout posting a pic...
like this:
[img] *post web link here-www.whateverblahblahblag.com.jpg - * [/img]
Old May 25, 2007 | 03:14 PM
Impact9's Avatar
like this:
I clicked on your link but I get a server not found error.
Old May 25, 2007 | 03:38 PM
luke280's Avatar
Impact9, getouttahere...
Old May 26, 2007 | 01:29 AM
loudmike's Avatar
i don't know about nav units, but the '07 6 disc i just got from a lariat had mounting brackets that were slightly farther back than the oem single disc in my '06. couldn't really tell until you laid them side by side and looked down at the tops of both. it was only about 1/4". but that was enough to make the panel not seat well. luckily the brackets were screwed in and i was able to drill new holes to offset the difference. after that the trim popped in fine
Old May 26, 2007 | 10:27 AM
Harley Boy's Avatar
Head Unit
Yea,
On the Nav the brackets are all the way to the front but the unit is thick and causes it to stick out further. It's a shame because it works so well. I'm going to take it back out and see if there is something in the dash I can change to get more room.
PS. Haven't learned how to post pictures yet.
Old May 28, 2007 | 08:18 AM
RI-Matt's Avatar
Harley Boy,
There was a thread a while back about how you have to dremel out the plastic in front of where the speed nuts are for the radio. There were even pictures !!! I had to do this in order to get a factory NAV unit to sit flush in my 06.
Do a search for "factory nav install" or something like that and see what comes up. I will see if I have the pictures somewhere.
Found it!!
https://www.f150online.com/galleries....cfm?num=12543
Matt
