TSB on 6 Disc Head Unit
Old Oct 9, 2006 | 05:56 PM
Gator Dad's Avatar
Post TSB on 6 Disc Head Unit
I took my KR Screw to the dealer and he showed me a TSB on the 6 Disc Head Unit. The CD was having a problem. Not sure of which specific model numbers are affected but I do know the 2006 Screw is one of them. The TSB said to replace the unit. If you are having a problem and it is still under warranty it might be worth a shot.
Old Oct 9, 2006 | 06:04 PM
medic2586's Avatar
if you find any more info on this...please post..anybody! thanks
Old Oct 11, 2006 | 02:12 PM
Gator Dad's Avatar
Smile Head Unit TSB
Just picked up my 06 KR Screw with the new 6 disc installed. They replaced the original one because it had CD error and would not load CD;s. This was covered under warranty. I looked again at the service writers notes and there is a TSB out on the 6 disc head unit. Hope it helps.
Old Oct 11, 2006 | 02:41 PM
Gipraw's Avatar
did they list the TSB # on your receipt ?
Old Oct 12, 2006 | 01:51 PM
Gator Dad's Avatar
There is no TSB # listed. It only says to replace under warranty. The notes I looked at were on a scrap piece of paper that was attached to my file. If I had a problem and the vehicle was out of warranty I would ask the service writer to look up the TSB. When my writer looked it up, it indicated on the computer screen, , that there was a problem and replacement was the only fix. I called Technicar to see if they knew of a TSB # they said no but they were replacing a large number of these head units. There seems to be a large number of the 6L3T18C815-FE (Part Number) that were having problems. It took three weeks to get my new unit due to backorders. The supplier had been overwhelmed. Hope this helps.
Old Oct 12, 2006 | 06:21 PM
medic2586's Avatar
keep us posted kay gator dad? thanks
Old Oct 13, 2006 | 11:36 PM
Gipraw's Avatar
thanks for the info .. .. mine spits out a disc at least once a day now .. used to be once a week .. so it is getting worse ..
Old Oct 14, 2006 | 10:06 AM
whitecrystal1's Avatar
Mine worked great until a little while ago it started spitting out discs. The error code was bad disc. The other problem was the reception on the radio started to suck. I told my dealer about it and they ordered me a new one and replaced it under warranty. The reception on the new one sucks to. It was fine when I bought my truck new.What happened. I have the 6 disc audiophile. Is there something I can do to help the reception?
