fm modulator
Old Dec 10, 2005 | 12:50 AM
wedgewood 4 x 4's Avatar
Red face fm modulator
has anyone ever used a wireless fm modulator i seen them on ebay and wondering if they are good. I have a 7 inch flipdown in my truck i want to put a dvd player in the center console , i need a way to hook up the audio and this looks like a good way to go no wires.
thanks for the help
Old Dec 10, 2005 | 04:24 PM
_SG's Avatar
_SG
I used FM modulation for Sat Radio in the past (wired). I set up my Father-In-Law's truck with XM and FM modulation (wireless). It's a proven way to get audio, but you definately sacraface quality. The center console on the '05 provides plenty of space to route wires, and provide power. I think in the long run, you'd be better off using the AUX button on you HU. The new PIE adapters work great. That's what I replaced my FM modulation with.
Old Dec 10, 2005 | 08:43 PM
where can i get a pie adapter for my hu.
Old Dec 13, 2005 | 11:46 AM
_SG's Avatar
_SG
The part your looking for is called: "FRD04-AUX" and can be found at the following websites:
http://www.logjamelectronics.com/piefrd04aux.html
http://www.installer.com/aux/
Read the application notes.
Old Dec 13, 2005 | 01:16 PM
Cannon00000's Avatar
Will this device work with my factory 2002 HU with 6disc changer, to run a Sirius device??
Old Dec 23, 2005 | 08:57 PM
_SG's Avatar
_SG
Sorry for the delayed reply. The unit I mentioned will NOT work with your 2002 HU.
There are two units for the 2002 found here: http://www.logjamelectronics.com/auxford.html
From LogJam:
We are told that there are a few Ford 6-disc in-dash CD head units that will work with the Aux Input Converters. You should remove your head unit, and get its model number, then phone PIE's Tech Support at 1-800-330-9754 to ask if your model has been successfully tested with the adapters.
Old Dec 23, 2005 | 09:22 PM
98Navi's Avatar
I use an audiovox wired modulator for anything I can straight wire in, and it is powered and switched. It works wonders for clarity. It ran me about $30 wholesale. I have a few NIB and one used if you want one from a definate source
