RDS Issues w/audiophile 6disc and mp3 hu
Old Nov 14, 2005 | 07:54 AM
lmtechinhouston's Avatar
According to the sticker on my truck, 05 f150 supercrew lariat, I have the audiophile hu upgrade with 6 disc and mp3 capability. In FM mode, I am not able to turn RDS on or off via the menu button, and it does not display any RDS info on the hu. According to my owners manual, I should have that capability. Anything I can try besides getting it replaced?
Old Nov 14, 2005 | 12:50 PM
frostby's Avatar
Are you certain you are tuned into a station that actually broadcasts "RDS"?
Old Nov 14, 2005 | 02:36 PM
Yep
yes absolutely, I have tried several different stations that I know broadcast RDS signals.
Old Nov 14, 2005 | 03:33 PM
frostby's Avatar
Ok! -Sorry for the patronization, none intended! I made the mistake myself of assuming I could get the info off the common stations, but to my disbelief, I could only recieve RDS on our PBS channel...
Old Nov 18, 2005 | 10:47 AM
Rugby09's Avatar
Well, your not alone with your RDS problem. I seem to suffer from the same radio problem you have described. No RDS. Have you contacted your Dealer? I called the Ford help line and they advised that I take the truck to the dealer. According to the Ford Help Line, the Audiophile systems are supposed to be capable of receiving RDS signals. I am going to stop by my local Ford dealer today. I will update the thread with my findings.
Old Nov 18, 2005 | 02:11 PM
2001SUPERCREW's Avatar
Me too! No RDS. And the volume comp. thing is a joke, goes from really low to high all the time. I will next time I need to bring it to the dealer have them look at it. It does suck because when they pull it to replace it I know it will a re-manufactured unit they are never as good as brand new. :santa:
Old Nov 18, 2005 | 08:46 PM
NR2D's Avatar
To turn on the RDS you haave to press and hold the "MENU" button. It will then come up and you toggle it on or off. I had to read the manual about 3 times to understand what the problem was when I got my '06 Supercrew home. Works great.
Rich Dunklee
NR2D
Old Dec 6, 2005 | 11:30 AM
found the problem
In the 05 supercrew, the 6disc with mp3 is manufactured by a different company. They switched to delphi after teh 04's were made. That is why I do not have RDS. It is not selection to trun on and off because it does not exist. Hope this helps ....
Old Dec 7, 2005 | 08:43 AM
ChandoJMC's Avatar
Really? I know they switched from Visteon ('04 only) to Delphi, but I'm pretty sure the '05+ Audiophile option still has the RDS option. The regular 6-disc MP3 option does not.
