Replacing stock HU AudioPhile Need help !!
Okay I have a 2004 f-150 screw with the audiophile system my stock unit has three plugs on the back and my wiring harness has three plugs that plugged into all of them. I repalced my stock deck with a in dash dvd. Its a pioneer AVH-P5700-dvd. The adapter kit for the pioneer only uses the main plug on the wiring harness not the other two. Its all wired in and working but now my stock sub and stock amp are not working. How do I wire these in? Do they sell a adapter that will turn the stock wiring into RCA plugs so I can connect it to my HU. Can I even get these to work with my deck? Any help would be great thanks.
Hey vapor, is this you?
peter_locke_iii
or
thefordfanatic
I was going to bid on it funny enough... Any chance of buy it now? Let me know ;D To answer your question If I understand you correctly you want to use the stock amp and sub with the new unit. If this is the case yes it is doable and I believe there is a description on how to do this in the forum if you do a search.
this should help get you started:
https://www.f150online.com/forums/sh...termarket+unit
Hope this helps,
Luis S
peter_locke_iii
or
thefordfanatic
Hope this helps,
Luis S
