Dynod my 01 HD today
Old Nov 13, 2002 | 09:47 PM
1JT's Avatar
1JT
Got off the dyno today. Here are the results. Red is Vortech SC only w/7.5 lbs of boost. Blue is Vortech SC, ATI intercooler, still 7.5 lbs of boost but had to put on a differant pulley due to lost psi w/intercooler and a JL Diablo chip. No very impressive!
Old Nov 13, 2002 | 09:53 PM
Harley#356's Avatar
so what were your peak hp/tq#'s??? I'm not very good at reading dyno graphs.
did you do a base dyno before you got the s/c? i know you've had it for a little while now, so not sure if you did. if so, how much of an increase?
Old Nov 13, 2002 | 10:29 PM
1JT's Avatar
1JT
The blue color was todays hp=313 and the red line was about 6 months ago also about hp=313. Since orginal install items added were JL custom program, intercooler and a smaller pulley for the SC. Basically all those mods and no gain. (other than safer cooler gain with more room for a smaller pulley) and yes to the base before any mod hp=203
Old Nov 14, 2002 | 01:04 AM
skidmarkracing's Avatar
Air fuel numbers are crappy. Need to be corrected
Old Nov 14, 2002 | 01:44 AM
1JT's Avatar
1JT
Thanks, I have already e-mailed the tuner.
Old Nov 14, 2002 | 01:53 AM
cobrasvt1's Avatar
send john those dyno sheets that will help him tune th truck
Old Nov 14, 2002 | 10:00 AM
f150intally's Avatar
Did you have your chip tuned? Aren't the A/F ratios very dangerous?
Old Nov 14, 2002 | 10:28 AM
1JT's Avatar
1JT
It was supposed to have been tuned still waiting to hear from the tuner. Its comming off today.
Old Nov 14, 2002 | 12:14 PM
JaxHarley's Avatar
Whats the altitude...is that corrected HP?
Also why was the dyno run done through 3 full gears?
The A/F ratio is really thrown off by the shifts.
it might not actually be that bad.
After the second shift it never gets above 13:1 and gets really rich (which is certainly where I would want to be when running boost).
Getting down to the 10:1 a/f ratio is probably hurting your power a bit and your power begins to drop off after that.
Old Nov 14, 2002 | 03:05 PM
1JT's Avatar
1JT
Hope this helps to answer your questions
Old Nov 14, 2002 | 11:12 PM
JaxHarley's Avatar
Those numbers dont exactly match whats on the screen...do they eliminate the shift point readings or something?
Id be happy with the A/F numbers on that list..but not on the dyno sheet.
Its obvious that right around 92mph that you are well below 11.8:1 a/f ratio (the lowest number shown on that second list). Something doesnt jive
Old Nov 14, 2002 | 11:32 PM
Ian N's Avatar
I agree - the A/F on the screen is scary but the one on the chart is not so bad. Also, did you have a big fan blowing through the I/C? An Air to Air won't do much without a lot of airflow.
Ian
Old Nov 15, 2002 | 01:49 AM
1JT's Avatar
1JT
Yes had a fan blowing on the IC.
BTW what color are you reading? The blue is what is reflected on the chart. That was my most recent dyno. Mods included w/ blue are SC, IC, 10lb pulley and chip.
Red= orginal install a few months ago w/ only the SC and stock 8lb pulley.
Old Nov 15, 2002 | 05:36 AM
HeHateMe's Avatar
That dyno is all over the place, dont you think your car needs to be tuned? I have never seen a dyno look like that.
Old Nov 15, 2002 | 09:27 AM
JaxHarley's Avatar
Probably doesnt have smoothing set to a very high level.
My bad...I thought you said yours was the red one...
Except for that section around 65 - 80mph where the numbers are in the 14s...id be happy...then again that looks like a shift point.
