MAS sensor and Fact. Tech. Valve Body
Old Jul 12, 2002 | 11:42 PM
Db682's Avatar
Thumbs up MAS sensor and Fact. Tech. Valve Body
Has anybody that has installed there MAS sensors figured out how to get rid of the whisttle. The freaking thing screams when im hauling ***. And by the way. I recommend the Factory Tech valve body. The thing is unbelievable. Im just pissed cause when i installed my new Autometer Column Pod and luner Trans temp gauge the Light didnt work in the gauge. Its defective. But Summit said they will have a new here for me in 3-5 days.
Old Jul 12, 2002 | 11:43 PM
Db682's Avatar
Installion on all is a piece of cake. The Valve Body is a little messy but well worth it.
Old Jul 15, 2002 | 01:44 PM
slingshot's Avatar
Yep--Love the valve body!
Old Jul 15, 2002 | 06:55 PM
Db682's Avatar
Rob,
Did you put a tranny temp gauge in when you changed your valve body and pan. I swapped pans for a B&M from summit and put a Luner Trans temp gauge from Autometer w/ the column pod. The gauge matchs the Harleys dash lighting perfectly. I bought a Trans temp manifold and a bunch of extra connectors and never used em. I just tapped in to the test port on the top of the tranny. That was Gregs (mister factory tech. himself) recommendation. If anybody needs it let me know I get rid of it for dirt cheap. Anyways i was wondering what temps are about average for Fords.
Old Jul 15, 2002 | 07:19 PM
slingshot's Avatar
Nope. Never really thought about it... good idea though. I probably should have waited on the Lunar gauges, but they said it would be a couple of months when I got mine and patience is not one of my stronger attributes . I do like the Ultralite gauges very well though.
Old Jul 17, 2002 | 02:47 AM
Factory_Tech's Avatar
Glad you like the valve body. I have a forum at
http://www.nloc.net/forum/forumdispl...s=&forumid=452
if anyone has questions about the transmissions. My day job is 4R100 repairman at the Sharonville Transmission Plant (where the transmissions are made) so I can ussually find an answer to your general questions about 4R100s.
G
Old Jul 17, 2002 | 10:53 PM
Db682's Avatar
Problems w/ Fact Tech. HELP!!!
Greg,
You are the man. That thing is awesome. Only problem is. Well this morning I left for work a little late (Phucking A.C. unit is in my attic in the garage and being that I live in Fl. the humidity has been causing the thing to sweat a like a !@#$$. Drain got cloged and attic and garage flooded over nignt. Those thing produce a hell of a lot of water.) Well and long story short while test drivng the truck w/ the new valve body at a high rate of speed i ran into a little problem. Hope you warrant this.
He rode a motorcycle and had some flashing lights and a rader. *****!!! Not again. 4th one in 3 months. I need a fuzz buster. or a skinny foot. FUZZ BUSTER. Valintine one time.
Old Jul 19, 2002 | 02:46 AM
Well, the warranty on the shift kit is pretty good (if it has a problem, I replace them, no questions asked, if it's mine I'll fix it), but I cn't cover the "public exhibition of speed" claims, sorry.
I use this, myself, when you absolutley, positively have to know...
http://www.escortstore.com/srx.htm
G
