Paging clonetek...
Paging clonetek...
Just ordered JL's 6# lower pulley, dual ram air and a dual program Delta Diablo chip... now need to do the tranny upgrade--you had earlier stated you could get the 4x4 pan and shift kit. Can you help me? I want to do this right, this looks like the way to go. Thanks.
go here and order one from the guy that makes them: http://www.nloc.net/forum/forumdispl...s=&forumid=452
http://store.summitracing.com/partdetail.asp?part=24837
This is link to the sway bar from Summit
Part no.
HEL-7621
Part no.
HEL-7621
Probably gonna have to get that sway bar... I'm a little confused--does Greg sell the kits? Or do you have to go through one of his retail accounts (JDM/PSP)???
I don't sell retail, PSP has them.
www.powersurgeperformance.net
They work in all the supercharged HDs, it's the same tranny as the lightning.
G
G
slingshot,
You might want to give Mark @ www.lightningforceperformance.com a try. Since he's in TX, you'll probably get your stuff quicker. Regarding the pan, I would suggest going to your local dealer for it since it's $36 list. Get the filter @ Autozone.
Hope this helps,
Edward
Hope this helps,
Edward
The part number for the filter at AutoZone is Deutch TF 325, the pan from the dealer is F81Z-7A194-BA, you don't need a gasket, the one you have is reusable, you'll need 8 Quarts of MERCON fluid, takes about 7-8 to fill the deep pan, kit comes with good instructions.
G
G
