Ford Tonka Truck
Ive made a couple calls today to double check if there is going to be any other lines of the HD trucks besides the f150 and that is a big negative. In my gallery ive posted alot of new pics of what is to replace the HD once the contract is up in 2005. The Ford f350 Tonka truck and the Equator will be the next line ford releases. The Equator is something like the Chevy Avalanche being that the rear window folds away. The tonka is an unbelieveable truck. Here are the specs. for the tonka. The Equator uses the same F150 or F250 engines w/ minor upgrades that are being used today. Ford Mighty F-350 Tonka Concept Technical Specifications
Dimensions
Length: 242 inches
Width: 93 inches
Height: 84 inches
Wheelbase: 165 inches
Track width, front: 74 inches
Track width, rear: 80 inches
Engine
- Power StrokeŽ Super-600 concept: 32-valve, turbocharged, 6.0-liter V-8 diesel with cast iron block and heads and forged steel crankshaft
- Displacement: 363 cubic inches / 5,954 cc
- Bore: 3.74 inches / 95.0 mm
- Stroke: 4.13 inches /105.0 mm
- Compression Ratio: 18.0:1
- Injection: Electro-hydraulic w/Generation 2 fuel injection
- Turbo: Electronic Variable Response Turbocharger (EVRTTM)
- Emission Controls: Diesel oxidation catalyst, electronically controlled exhaust-gas recirculation
- Horsepower: 350 @ 3,300 rpm (estimate)
- Torque: 600 lb-ft @ 2,000 rpm (estimate)
Transmission
- PowerTorq? five-speed automatic concept
- Gear Ratios:
1st 3.09
2nd 2.20
3rd 1.54
4th 1.00
5th 0.71
Reverse: 2.88
- Shift control: Fully electronic solenoid control of clutches with adaptive learning capability
Four Wheel Drive System
- Rear- or four-wheel drive with low-range transfer case and limited-slip rear differential.
- Manual Torquemaster override
- Front: Live axle with air springs, stabilizer bar
- Rear: Live axle with air springs
Brakes
- Four-wheel disc brakes
- Four-wheel anti-lock brake system
Wheels and Tires
- 22 x 11-inch chrome wheels
- 315/60R-22 Goodyear tires
- Dual rear wheels
The Mighty F-350 Tonka Check My gallery for pics. They are in the "How bad have you got it" section
Dimensions
Length: 242 inches
Width: 93 inches
Height: 84 inches
Engine
Transmission
- Gear Ratios:
1st 3.09
2nd 2.20
3rd 1.54
4th 1.00
5th 0.71
Reverse: 2.88
Brakes
Wheels and Tires
- Dual rear wheels
