installed swaybar & drop shackles on 02 HD
Old May 21, 2002 | 03:32 AM
clonetek's Avatar
shackles were easy.. sway bar was a PITA! lol *yawn*
Old May 21, 2002 | 09:04 AM
Mystery Fan's Avatar
Registered User
The sway bar really wasn't that hard, the instructions looked like they had been copied 4,000 times. Once we figured it out, it was easy. If anyone decides to tackle this little project, we can answer your questions. The sway bar cuts down on the curve lean about 75-80%.
Old May 21, 2002 | 09:49 AM
croosr's Avatar
Sway Bar - Which One?
Are you using a Lightning rear sway bar, or???
Do you have the part number for this assembly? Thanks.
Old May 21, 2002 | 10:27 AM
clonetek's Avatar
the swaybar is a aftermarket hellwig unit for 97-02 f150's.
Old May 21, 2002 | 11:29 AM
N2TRUX's Avatar
Just curious? Would the L sway bar be a bolt on or not?
Yeah, I know ones a reg. cab, and ones a S-crew, but what's the real difference in the frame at the rear? Seems to me it might be easier. I'm sure the factory bar would be more $$$ though...
Old May 21, 2002 | 11:58 AM
clonetek's Avatar
someone said they took the rear swaybar off their lightning and put it on their new HD.. the bastard.. lol
imagine the poor fool that gets a lightning without a rear sway bar..
Old May 21, 2002 | 04:50 PM
Harley#356's Avatar
got a link to the gallery from where those pics are???
how much was the sway bar, and would it help alot on my 00 HD?
Old May 21, 2002 | 05:10 PM
clonetek's Avatar
https://www.f150online.com/galleries...TOKEN=63363168
Old May 21, 2002 | 11:45 PM
Blake Bowden's Avatar
Clonetek...I noticed that you have a 00L...if that's the case you have a DAMN clean looking under. If it's a 00 do you use it as your daily driver?
Old May 22, 2002 | 01:11 AM
clonetek's Avatar
blake: read the heading again.. i installed the stuff on a friends 02 HD (harley davidson f150). its brand new.
the underside of my 2000 lightning is pretty nasty.. i drive it every day. almost 36K miles on it..
the lightnings have swaybars front and rear stock..
Old May 22, 2002 | 01:30 AM
Red face
Haha..DOH...had a brain fart or something...damn, I need to goto bed
Old May 23, 2002 | 06:57 PM
lrutt's Avatar
What was the part number for the sway. Helwig offers a few types depending on the amount of drop you have. Our HD's are an inch lower than stock, plus a 2" shakle, would make 3" down from a stock F150. Did you use the 2" drop sway or the 4" drop sway??
Old May 23, 2002 | 09:37 PM
clonetek's Avatar
HEL-7621
he got the swaybar from summitracing.com for $129.
its the one for 97 & up f150..
Old May 23, 2002 | 09:45 PM
Registered User
We used the standard sway bar! We couldn't tell a difference, the sway mounts forward of the axle. The front of the spring is not lowered just the back by 2 inches.
On the lightning it mounts in the back of axle which might make a difference.
