Side shot of Lowered HD?
I will soon. If your thinking about lowering. I highly recomend it. I lowered mine and it's just the perfect distance off the ground for me. Low enough you can tell it's been lowered. But high enough it doesn't bottom out. If your considering doing this. Go for it.
Well..I actually tow things
Ive already put on the drop shackles in the rear to level it out..however when i bolt up the trailer...it sags a pretty good bit.
Dropping the truck to the ground would most likely make towing impossible. I just wanted to see the look and height of the truck after its been done.
B
B
Go to fordharley.com
My truck and FLHR are featured on the home page. It has the SoCal 4/3 drop.
Cannot get a finger between the rubber and fender edge. It looks like the tire just fits inside the wheel well, which was what I was looking for. It rides a bizzilion times better that before. I think with the new Hotchkiss (basing this on their rep) swaybars the handling ought to be on par with the ride. Even the "picky" wife likes the new ride (no chicken neck).
