Dim Headights???
Old May 31, 2001 | 08:50 PM
rubbermann's Avatar
Post Dim Headights???
The other night I was driving around town and I noticed that my driver side headlight was dimmer then my passenger side. The headlight had the same brightness as some sort of daylight running feature. The next day I turned on the headlights and everything was back to normal. This is the second time that this has happened. anybody
Old May 31, 2001 | 08:59 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Post
check the connection to the light first. if it continues replace the blub.
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Better 1/2 : 92 Red T-Bird.
Old May 31, 2001 | 11:59 PM
casey k's Avatar
Post
there is a recall up here in Canada to replace the DLR resistor due to corrosion safety Recall # 00S29 which causes the DLR function to not operate covering '99,00,01 F150, F250, Expedition & Navigators. If you don't have the DLR function don't know if it applies, but it may--worth checking out. Haven't had mine done yet--my DLR is still functioning.
