Tire Pressure??
Old May 7, 2001 | 07:06 PM
Alf's Avatar
Alf
Post Tire Pressure??
Can someone please tell me what is the recommended tire pressure as per the sticker on the door? I just got a set of wheels with 275/45/20s tires and they came at 41 psi.
Thanks in advance.
Alf
2000 Silver XLT 4.6 Extended Cab
Stuff I Got:
- ARE Z-series color matched cap (for my Rotties...)
- Flowmaster 40 series with Edelbrock oval tips
- Airaid intake system
- 500 watt sound system (Sony CD player, Lanzar EQ, Profile amps, Polk speakers, Kenwood subwoofer)
- carbon-look emblems
- dropped 3/5
- clear corner lenses
- color matched Street Scene mirrors
- Superchip
- 20" Alessio Daytonas with 275/45/20 GTII rubber
Stuff To Get:
- SVT bumber cover (on its way...)
- Cervini's or cowl hood
- supercharger (twin screw type)
Old May 7, 2001 | 09:22 PM
harleyrules's Avatar
Post
I run mine at 40 psi
HD F150
2000 FLHTCUI
1970 OLDS Cutlass W 31
2000 Lincoln LS
Old May 7, 2001 | 09:48 PM
Neal's Avatar
Cool
HI!... The "ALL AROUND" best tire preasure is 32-33PSI. This has been proven to give the best tire wear and FUEL milage. I run my fronts at 32PSI and my rears at 28PSI. If I were to run my rears at 41PSI, I would burn my tires off all the way through 2ND gear!LOL!
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old May 7, 2001 | 09:51 PM
BlownHarleyFord's Avatar
Post
Neal, you're not running 275-45-20's. I'm with Harleyrules. 40 Psi runs well for me. A little stiff, but I's rather have a bumpier ride as opposed to wrecking a $1050.00 rim. But that's just me.
Mike
"Stay Out Of My Taildust"
2000 Black Harley Davidson F-150
5.4 Liter V-8
K&N Air filter
SuperChip FlipChip
6 Disk CD Changer
Sliding Rear Window
Heated Seats
Hidden Hitch
Lund Front Blackouts
GTE Rear Blackouts
Block heater
McGard Wheel Locks
CodeAlarm System
Air Force One FIPK
BedRug
Old May 7, 2001 | 11:16 PM
HarleyGuy's Avatar
Cool
Me three. 40 PSI it is.
2000 F150 Harley-Davidson: Superchip, K&N FIPK
Hard Tonneau, Hidden Hitch, 2-Meter Rig (KG0UK)
Motorcycles: '99 FLHRCI, '95 XLH, '65 305 Dream
Old May 8, 2001 | 09:27 AM
Alf's Avatar
Alf
Thumbs up
40 it is then...
Thanks guys!!!
Alf
Old May 8, 2001 | 11:27 AM
Chuck98GT's Avatar
Post
I just got mine last Friday and felt it pulling to the right. Turns out the right tire had about 31 psi and the left had 40 psi. Set all four tires to 35 psi per the sticker in the drivers side door jam and the truck drives better.
-Chuck
Old May 8, 2001 | 06:25 PM
Alf's Avatar
Alf
Post
Thanks Chuck98GT,
That's what I wanted to know, what exactly the sticker says.
Alf
Old May 8, 2001 | 10:51 PM
2000F150HD's Avatar
Post
i run about 38 and it is good. if you run 32 and 28 in the 20s you are going to run into trouble. on my stock HD i cant spin my tires runnning 38 psi.
-steve
2000 F-150 Harley Davidson Edition
Mods-
-Foglight Mod
-python 3000 alarm
-pics
Old May 18, 2001 | 12:25 AM
casey k's Avatar
Post
my tires came at 44 from the dealer; tried 40 but felt a little spongy so am sticking to 42 to 44. I'm used to hard tires (g force Goodrich on an SVT Contour) and like the crisper cornering with the higher pressure. A lot depends on the roads in your area. You gotta protect your rims as well. Anything less than 40 tho doesn't do justice to the truck in my opinion tho.
Old May 19, 2001 | 09:29 AM
Tampa-Harley's Avatar
Post
I have worked for goodyear (the goodyear company, not a dealer} and for other tire Companys, I work for Ford now and my 2000 HD F-150 says 35 psi front and rear. That is what I run and that is what I recommend. Now the 2001 supercrew maybe another pressure but I don't have that info here. I will check and get back with you. Ford sets there tire pressure recommendations based on safety and handleing, its not set for comfort or treadwear.
Old May 22, 2001 | 12:12 AM
casey k's Avatar
Post
Hey Tampa-Harley: given the latest blow out between Ford and Firestone/Bridgestone on the Explorer situation I'm not sure I'd put much credence on Ford's recomendations: 28psi on an Explorer just seems too low for any tire with all that weight to carry as well as the heat you guys enjoy down south I've been using performance tires on my cars since'73 and along with most guys in the car clubs I've belonged to, tend to go halfway between the tire/vehicle manuf re tire pressure; have always met or exceeded tire wear mileage while retaining various vehicles' max handling capabilities. Agreed that most people prefer a softer ride and therefore go with lower pressures but I'm more comfortable with a bit more air to give crisper turnins etc. The roads my HD mainly rides are 2 lanes, fairly smooth with some bumpy sections--just bumped up from 38 back up to 42 today after experimenting again and I just like the road feedback more at 42. Keep us informed. Thanks.
Old May 22, 2001 | 09:46 AM
HarleyGuy's Avatar
Post
I just bought a 2001 Mercury Mountaineer this weekend and it has Firestone Wilderness ATs on it. Guess Ford hadn't cut the ties with Firestone yet when this one was built! Also have to wonder how come Mercury division didn't get involved with the big tire recall? Basically, the Mountaineer seems to be an Explorer with some addl. features and, perhaps, more insulation.
Anyhow, the recommended pressure is 30, the sidewall max pressure is 35. I put in 33. I agree with casey k above nearly 100%.
