Lastest Mods
Well, here are the lastest mods to my truck:
Air Force One
DJM Shackles 2 inch drop rear
Lightning Headlights
Lightning Corner Lights
Lightning Tail Lights
Super Chip
Keypad
and there is more
HD F150
2000 FLHTCUI
1970 OLDS Cutlass W 31
2000 Lincoln LS
Air Force One
Super Chip
Keypad
and there is more
HD F150
2000 FLHTCUI
2000 Lincoln LS
She rides and handles like a dream. reaaly takes the curves without any body roll. I am very happy with this mod and it only cost 36.00 and 20 minutes of work.... : )))
I got them from www.godfathers.com
HD F150
2000 FLHTCUI
2000 Lincoln LS
HD F150
2000 FLHTCUI
2000 Lincoln LS
Got any pictures. I measured mine and 2" in the rear would make the wheel gap exactly the same front and rear. If I ever load or pull a trailer it would be tail draggin, unless I drop the front some as well. Starts to get more complicated. Not sure what I want to do yet.
- 2001 F150 Harley Davidson Special
- 1993 Mazda Miata, wifes car
- 1994 Harley Davidson Heritage
- 1976 Honda CB750K, Original
- 1965 Honda 305 Dream, Original
- 1971 Triumph Trophy 650, Original
- 1971 Norton Commando
- 1970 Honda Trail 90, Original
- Yamaha 500 Short Tracker, racing #69
- 1984 Yamaha Virago 1000, wifes bike
- 1981 Honda Passport 70, wifes bike
Hauling your bike wont make any difference. The rear will not drop any lower then before. The shackles do not lower your load carrying abilities. No pics as of yet. Sorry
HD F150
2000 FLHTCUI
2000 Lincoln LS
HD F150
2000 FLHTCUI
2000 Lincoln LS
Please excuse my ignorance, but I've been wanting to lower my truck and have seen things costing as much as $1500. Are you saying using ONLY these shackles, I can lower the truck? Also, can the same be done on the front? I too haul my bike in the bed and will try to put my wifes in as well. Total about 900lbs. This weight winn not have any ill effects? And finally, how would the warranty be affected? BTW, the link goes to Godfather's Pizza :-) Thanks in advance.
Gene from AZ (now)
US ARMY DRILL SERGEANT
HOOAH!!
HIS:
00 HD F-150: Clear corners, bug deflector and ventvisors, 01 Lightning tail lights
00 Triumph Daytona 955i
HERS:
01 Nissan Pathfinder
00 Buell Blast
Gene from AZ (now)
HOOAH!!
HIS:
HERS:
00 Buell Blast
Hi Badgene,
Okay, Here is the scoup.. I did lowering shackles to the rear leaf springs. They lowered the rear 2 inches so the back was even with the front. I got DJM SHACKLES from Godfather customs 1-800-231-1101 I don't recall the part number at this time. But they will be able to give it to you. Hope this helps
HD F150
2000 FLHTCUI
2000 Lincoln LS
HD F150
2000 FLHTCUI
2000 Lincoln LS
Shakles will only lower the rear, not front. It shouldn't hurt the warranty unless you started eating u-joints or something, then they might try and blame the change of angle of the drive shaft or something. With 900lbs of bike in the back on a 2" lowered rear you'd definately be tail draggin. Your springs are still the same so the only limitation will be that you might contact the bump stop on the rear axle and frame sooner thant if it was still stock. I won't even consider trying to put one of my big bikes in the back of my truck, to damn far off the ground. I'll trailer if I have to.
Aprreciate the info. Here's another question. If I do go with the shackles for the rear, what can I do with the front? Or should I just leave it be? I'm not looking for the typical lowrider, slammed look, just a lower profile.
Gene
PS Since 900 lbs may be a bit much, my wife better be prepared to putt around behind :-)
Gene
I did the So-Cal thing: The kit came with front coils, Moog front alignment kit, 4 shocks, rear shackle kit, and a rear helper springs.
Drops the truck front and rear while maintaining the original load carrying capacity. Shackles alone will decrease your load carrying capability...do it right the first time. Cost $745 + delivery. All quality components. Shipped within a week. Put it in over the weekend.
No affiliation. Just a happy customer.
I also used the a Kit pretty close to the so-cal, worked out to about $1400 cdn. Loks and rides great. Also got the kit quick and was an easy install. Very pleased with the look. Not to low, just enough to fill the gap around the tires.
Lowrider--talked to my dealer about lowering and was quoted aprox $1k Cnd including labour. All Ford parts so no warranty hassels. How much are you now lower from stock, front and rear? And the kit includes new shocks--better or worse than the orig? Better handling? Does it still look like an Alberta truck or is it now more SoCal? Any pix you can share since I'm thinkin' Thanks.
