Need info on installing 01 Lightning Head and Corner Lights on a 01 HD SuperCrew
Old May 14, 2001 | 05:20 PM
MotorWorf's Avatar
Post
They should be exactly the same as my Y2k model. First, lift the hood
Sides: Directly on top of the sides is a screw (9/32" I believe) that you remove--it will also take a torx drive; but I found it easier to use a socket. Then, with the whole palm of your hand on the side of the light, push towarde the front of the truck and the assembly will come loose. It then just slides forward and out of the truck.
Fronts: It is in your owner's manual. Same as replacing a headlight
In fact, the sides might be their also as the process to replace the bule is the same.
Old May 14, 2001 | 06:39 PM
BigBlackHarleyF150's Avatar
Post
Thanks MotorWorf,
I'll try it tonight.
Old May 15, 2001 | 12:45 AM
Post Need info on installing 01 Lightning Head and Corner Lights on a 01 HD SuperCrew
Any help will be appreciated.
