Lightning Tail lights installed!!
<font face="Verdana, Arial" size="2">Originally posted by harleyrules:
Can't you just buy the screws from Ford, the same ones used on the Lighnting? Would that make life easier then using washers or cutting the stock screws that came on our trucks?
</font>
</font>
Mike
Stay Out Of My Taildust
2000 Black Harley Davidson F-150
5.4 Liter v-8
K&N Air filter
20" Polished Aluminum Wheels
275/45/20 Goodyear GSII's
Billet Front Grille
Front Valence W/ driving lights and Billet Insert
3.55 LS Rear End
Leather Interior
6 Disk CD Changer
Sliding Rear Window
Heated Seats
Hidden Hitch
Orange Pinstriping
Lund Front Blackouts
GTE Rear Blackouts
Lowered 1" Front & Rear
Block heater
McGard Wheel Locks
Thanks for the detailed and good explanation, baddgene! I went and looked inside the tailgate as you suggested and can see there is plenty of room in the recessed holes for washers.
Won't likely find the rubber coated ones as you used, but it looks like about any washer will work OK.
2000 F150 Harley-Davidson: Superchip, K&N FIPK
Hard Tonneau, Hidden Hitch, 2-Meter Rig (KG0UK)
'99 FLHRCI, '95 XLH
'99 FLHRCI, '95 XLH
baddgene, how many screws hold the lights in? Just the two that are seen when the tailgate is lowered? How much shorter did you make the screws with the washers -- sounds as if you put two 1/4 inch washers on each screw to shorten each screw a full 1/2 inch? They must be long screws?
Thanks,
Don
Thanks,
Don
HarleyGuy, two screws hold each tail light in. Once you take the screws out, you have to manipulate (slide) the entire lens towards the rear of the truck. Then you'll see that there are two "****" for lack of a better word, on the lens holding it in place; like a puzzle. I believe the screws are 1 1/2 inches long and they need to be probably 1 1/4. You're right any washer should do, as long as they are 1/4 inch washers; to fir the screw and the recession in the truck. If you like, I can send you the washers I used, they are perfect. They only cost 40 cents so it's not a problem really. My way of giving back for the help I've been given. Just lemme know Bro!
US ARMY DRILL SERGEANT
HOOAH!!
HIS:
00 HD F-150: Clear corners, bug deflector and ventvisors, 01 Lightning tail lights
00 Triumph Daytona 955i
HERS:
01 Nissan Pathfinder
00 Buell Blast
HOOAH!!
HIS:
HERS:
00 Buell Blast
Hey Harleyguy ... or anyone else looking for those washers, you probably have a NAPA auto parts store somewhere near you, there's like 6,000 in the U.S. Call and ask them for Rockford part # 8069-035 galvanized washer with bonded neoprene. Neoprene helps insure you don't get water leaking in around the screw shaft.
I just installed the '01 L taillights on my '97 flairside. You can use fender washers (the ones with smaller holes) for this install. I recomend using stainless ones if you can get them. No need to use the special washers with the neoprene as the factory screws are self tapping (notice the screw holes have no thread). Four washers per screw is what I used. They are slightly wider than the factory screw washer is. Also, the part # for all '97-2001 screws is the same. You'll love the results. Good luck!
i like the tails but i dont know if i like the look on the HD. i think it makes it look a bit like a ricer. im not shure though. i am almost nutral about the looks so i dont know if i would spend the money. i lone the headlights and corners though. i think i will get those for shure. where did you all get your lights? is there any place online? also did anyone get the 3rd breaklight from the lighting? how do you like it?
-steve
2000 F-150 Harley Davidson Edition
Mods-
-Foglight Mod
-python 3000 alarm
-pics
-steve
Mods-
-Foglight Mod
-python 3000 alarm
-pics
